CUCM sql commands using concat
Neil Martin
Community Member
I'm trying to run some sql commands on the CUCM and want to use concat.  For example I have tried all of the following:
admin:run sql select concat(firstname, ',' lastname) from enduser;
admin:run sql select concat(firstname || ',' || lastname) from enduser;
admin:run sql select firstname, lastname SET firstname = (CONCAT(dnorpattern, ',')) from enduser;
It seems that concat just doesn't work as I get 'syntax error' every time.
Can anyone let me know if this can be made to work?
Thanks in advance,
Neil
9 Replies 9
Mohammed Khan
admin:run sql select firstname,lastname from enduser
firstname lastname
Mohammed  Khan
Asif      Khan
Emergency Responder
Jonny     Walker
James     Bond
admin:
Thanks for your reply Mohammed.  What I'm trying to do is get output like this:
firstname,lastname
JOHN,SMITH
JANE,DOE
Unfortunately the above in your reply doesn't do this for us.  When I run this on a mysql database the command is select concat(firstname,',',lastname) from enduser.  I know that 'concat' is an option in db2 but it doesn't seem to work on the appliance.
Other way around to achieve this is thru BAT user export.
Do you mean BATCH mode?  Problem at the moment is we don't have permission to write to a file.  Can you confirm if it is possible to run concat or not with CUCM?  If so what is the correct syntax please?
You can use concat in update query, Seems select has a limitation.
Why not just run the query you have and then copy and paste to Excel and concatenate the cells there?
f.hallier
Community Member
Hi Neil,
May be late for you, but the following could help someone else...
run sql select firstname || ',' || lastname from enduser
i tried your suggestion using double pipe (||) characters. But the SSH Session does not accept it. Copy/paste is not working, also. CUCM Version 11.5.1.12900-21
Is there any way around this?
/Robert
valerie.kan
Level 3
Level 3
It looks like concat just doesn't like taking more than 2 parameters.
run sql select concat (firstname, lastname) from enduser
worked for me.
I also tried
run sql select concat ( concat (firstname, ","), lastname) from enduser
Hope this helps.
