06-01-2017 02:12 AM - edited 03-19-2019 12:29 PM
Hi All,
We are working with Cisco call manager on a LAB enviroment, we are testing call between 2 Cisco Jabbers registered in the CUCM server. All the calls are disconnected after of 18 seconds, the discconect Cause is: Call having the requested call identity has been cleared (86)
Calling Cisco Jabber ip address: 10.30.193.135
Called Cisco Jabber ip address: 10.30.195.144
Cisco Call Manager ip address: 10.30.135.118
I am sending atteched the Wireshark trace captured.
Could you help me with this issue?
Thank you,
Best Regards,
David Lozano
06-01-2017 02:29 AM
Looks like you only took the captures from 10.30.193.135, not enough information.
Make another test call and provide calling \ called and attach call manager traces from all servers.
JB
06-01-2017 03:02 AM
Hi Jitender,
Thanks for your answer.
As it is a LAB eviroment we cannot downlodad traces from Cisco call Manager, it is a problem for us.
Do you know if there is some Enterprise parameter that could affect to this option or something in the configuration?
Thanks for your support,
David Lozano
