CUPS Instance Msg Delay
zl
Level 2
Level 2
My CUPS 7.0.2 integrated with CUCM 7,All of those function work correctly,except the IM.the msg send to another user always delay more than 20s,Instance Msg not immediately!!
pls help me~!
10 Replies 10
gogasca
Level 11
Level 11
Whats the topology?
Are you using this over VPN?
All PCs same LAN?
CUPS and PCs using proper DNS server?
All server and computer are in same VLAN and use same DNS.
someone there?
htluo
Level 11
Level 11
1) We need proxy log on debug level with following options:
a) Enable SIP Message and State Machine Trace
b) Enable SIP TCP Trace
2) We need presence engine log on debug level
3) You need to recreate the problem before collecting logs. Send one (and only one) message.
4) Let me know the sender and receipent's user ID and the content of the message.
Michael
http://htluo.blogspot.com
Hi,Which guide should be reference to do this process?
I am confronted with the same problem, too.
The environment is also the same.
(All server and computer are in same VLAN and use same DNS.)
I want to know the method of settlement if it has already solved it.
I have no idea.
When Reverse Lookup Zones was put in the setting of DNS, it solved it.
Thanks.I will try later.
