customize script for autoattend prompt in UC540
edwincharles
HI,
I would like to create a customized script for auto attend for UC540, with the attached files.
Please if anyone can help me in it.
gkannapp
What is the UC Software pack you are using. Are you using CUE 8.6.x version, if so you can try CUE editor express using the webadmin GUI.
In webadmin System -> prompts menu you can upload the greeting wav files that you wanted to use.
In System -> Script, you can click New and customize your AA script using the prompts.
Refer this link for working with custom scripts.
      http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008041d950.shtml
