Dial peer hunting !
Jonn cos
Level 4
Level 4
Hi all.
Lets say i have 2 dial peers
dial-peer voice 1001 voip
preference 0
destination-pattern 1001
session-target ipv4:x.x.x.x
dial-peer voice 1002 voip
preference 1
Now according to my understanding, following shall happen (pls correct me if any step is wrong)
1) When the call comes in with DNIS 1001, first dial-peer 1001 will be selected.
2) If the dial peer is already busy, 1002 will be checked
3) (this is my confusion) what if 1002 is also busy ? will it revert back to 1001 or try to match some other dial peer  ?
Is there any timeout value that can be configured as to for how long the dial peer hunting shall continue ?
Marcel Ammann
Level 3
Level 3
you can use the following configuration:
max-con 2
After 2 connections the first dial-peer is busy, and the second dial-peer would be used.
If you add max-con 2 to the second dial-peer you can make 4 calls with the obove dial-peers.
After all dial-peers a busy the logic trys again the first dial-peer. You can use a huntstop command to stop the hunt process.
Kinde regards,
Marcel Ammann
