Dialing Digits with TCL over SIP
markus.eissele
Hello together,
we are using a tcl script dialing some digits with "leg senddigit". This is working fine on an ISDN with an pots dial-peer.
Now we try to implenent the script on a Gateway using SIP to the Provider. Here we are not able to transmit any digit.
Have someone experiences with dialing digits oder SIP/Voip.
Thanks for help
mached dial-peer for Service
dial-peer voice 400 voip
description to_SIP-Provider
service directcall out-bound
destination-pattern <phonenumber>...
session protocol sipv2
session target ipv4:10.100.46.49:5129
voice-class codec 1
voice-class sip early-offer forced
voice-class sip profiles 44
voice-class sip bind control
source-interface GigabitEthernet0/1
voice-class sip bind media
dtmf-relay sip-notify rtp-nte
fax-relay ecm disable
fax-relay sg3-to-g3 fax rate 14400
fax protocol pass-through g711ulaw no vad
outgoing dial-peer to SIP Provider
dial-peer voice 100 voip
translation-profile outgoing STRIP-9
destination-pattern 9T
session target ipv4:xx.xx.xx.xx:yyyy
voice-class codec 1
fax-relay sg3-to-g3
fax rate 14400
0 Replies 0
