Document for upgrade path and procedure from cucm 8.6 to cucm 11.5
Mujeeb Shaik
Hi all,
Trust you are doing great,
Will be highly grateful if anyone can provide me a document containing an upgrade path and procedures for upgrading cucm 8.6 to 11.5
Thank you
Mujeeb
Jaime Valencia
The upgrade guides and RN available on cisco.com have everything you would need to plan and execute the upgrade, I made a video for reference to go along with the documentation.
https://youtu.be/aNkLMgQ8B3s
java
if this helps, please rate
Jaime Valencia
java
