Extension number revamp, can bulk edit tool help?
yewting
I need to change the extension number for 500 subcribers. Any tools I can use? Or the only way to do this is in the personal page on individual subcriber? Pls advise. Thank you.
lindborg
Bulk Edit can help if you're going to do this using a pattern (i.e. adding a "54" to the left of every extension or stripping off the leading two digits etc...) but it's not capable of reading in a CSV file or the like to change groups of extensions based on file input or the like.
However, the Cisco Unity Bulk Import tool (CUBI) can read in a CSV file and update extensions (and transfer strings if necessary) for existing subscribers - you'll find the tool in the Tools Depot (assuming you're running a recent version of Unity - you didn't indicate what version you're at) - check out the help on the tool for details on how to setup the CSV file to accomplish this.
I'm using Unity 4.0.3 SR1. Thanks for your help.
