11-29-2006 02:37 PM - edited 03-18-2019 06:40 PM
Greetings All,
If a user is a member of a group that gives them access to a GDM, is it possible for users to access the GDM via integrated messaging?
We have our uses set up with IMAP clients to access their personal mailboxes.
How do we configure the IMAP client to access the GDM or is this even possible?
Thanks in advance,
john
11-29-2006 03:47 PM
You should be able to add multiple IMAP profiles to your Outlook profile. If you are not using Outlook, I'm not sure if Outlook Express can handle multiple IMAP profiles.
Outlook gives you the ability to check multiple accounts at once. But does not give you the ability check different Exchange servers at once. (this by Profile only)
cheers,
11-29-2006 06:11 PM
Thanks for taking time to reply. We can add as many profiles as we want in our IMAP clients. We use Outlook and Thunderbird.
The issue is with a GDM, what credentials would one enter for the IMAP server login credentials? For a personal mailbox, we configure an IMAP profile with the username and password of the mailbox owner.
Since there isn't a UserID/password for a GDM, I'm lost when it comes to the specifics of configuring the IMAP profile for the GDM.
John
