Hi, I am trying to upgrade CUCM 7.1.5 to 8.6.2 and I am receiving a pop up that states
jcox82488
I am trying to upgrade CUCM 7.1.5 to 8.6.2 and I receiving a window after I reboot the VM. The installation is asking about a recovery disk?
It states my active partition as partition A
then the choices are:
[F]:[f] Check and correct disk file system.
[V]:[v] Verify the disk partitioning layout.
[A]:[a] Align partitions on disk(s)
[Q]:[q] Quit this recovery disk program
I choose V for verify and it just states that I was successful, I choose F to check and correct disk and it states that the check is fine, I choose A and it states that A is an option that is meant to be run for aligning partitions on hard drive(s) that have pre-existing, unaligned  partitions. Any data on the hard drive(s) WILL BE PERMANENTLY LOST!
Continue?[j/n]:
I am not sure if I should proceed with option A?
It appears to me that I may be running a recovery ISO, could this be correct?
John Cox
AT&T Voice Architect
keglass
Level 7
Level 7
John,
This community does not provide technical support and is not staffed with technical support experts. I recommend you post this and future technical support questions to the Cisco Support Community (https://supportforums.cisco.com/index.jspa) where our Cisco technical support experts provide assistance. Another option is to open a ticket with the Cisco Technical Assistance Center (www.cisco.com/go/support) to get expert debugging assistance.
I hope this helps. Thank you for participating in the Community.
Kelli Glass
Moderator for Cisco Customer Communities
