HOW 2 Upgrade unity 4.0 4 from MSDE to MS SQL 2000
allanwells
Whats the process to upgrade unity 4.0 4 from MSDE to MS SQL 2000?
Also see other question I have from cleint
Does Unity support the following
1) Full MS-SQL instead of MSDE ?
2) Remote MS-SQL on a separate server?
3) Named instances? (In support of above)
Thanks in Advance
Allan
lindborg
Check out the reconfiguration and upgrade guide here:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_upgrade_guides_book09186a0080222fdf.html
it has a section on changing from MSDE to SQL 2000 in there.
No, you cannot run SQL off box, it must be on the Unity server. Thus the named instance question is moot.
