How do we replace System Call Handler Message after leaving a voice mail message?
In Unity Connection 10.5, I would like to know how i can replace message  " To send this message press pound or hangup"  after leaving voicemail to local language or cut it out?
Thank you
Jaime Valencia
You would need to install a locale to get it in any other language.
java
if this helps, please rate
Hi Jaime,
My language is Thai, which I don't think it's main language like Chinese.  Is there any other workaround?
If you're asking if there's a way to load your own prompts, the answer is: no.
You'll have to settle for one of the supported languages.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/requirements/10xcucsysreqs.html#pgfId-585821
java
