How let GK route calls to CM ip phones with "static alias" command
youssef.ahmed
I made a h.225 trunk from CM to GK.This trunk not allowed to register to GK with tech-prefix.
Also i have not default-tech
I need to add CM ip phones static with "alias static" command .
Calls from CM to CME success BUT calls from CME to CM fail even i got from debugs that dialed digits successfully resolved.
What is the problem plz give configuration exampls
5 Replies 5
youssef.ahmed
GK conf. is:
gatekeeper
zone local IPIPGW cisco.com 192.168.250.101
zone local CM cisco.com
zone local CME cisco.com
zone prefix CM 1... gw-priority 10 H.225GK711Trunk_1
zone prefix CM 1... gw-priority 9 H.225GK729Trunk_1
zone prefix CME 3...
alias static 192.168.100.200 1720 gkid CM gateway voip ras 192.168.100.200 1719
e164 1000 e164 1001 e164 1002
no shutdown
youssef.ahmed Under the ccm service paramaters there is this
Device Name of GK-controlled Trunk That Will Use Port 1720 None
Host Name/IP Address of GK That Will Use RAS UDP Port 1719 None
Populate these accordingly AND restard CCM Service. All will work then!
HTH, Please rate the post if you find it helpful!
Chad
Those service parameters are already none ( nothing on them).
My Q. in other words to be more specific:
Can " alias static" command used to route calls to CM or not if trunks register to GK without tech-prefix??
I know, those are default of NONE. You need to set these to match your trunk you want to use alias static on. If these aren't set properly it will never work.
HTH, Please rate helpful posts.
Chad
Hi Chad,
It worked BUT if I should have two trunks in two regions(one in G711 & other in G729)
How I let two trunks accept calls from CME .?
