How to add opening greeting in call manager ?
I have installed b36k server.... the customer has recorded opening prompt in MP3 format .... how to upload in cisco unity ? what coded is needed ?
Kindly help me
Jaime Valencia
Use the media master to upload the greeting.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/administration/guide/9xcucsagx/9xcucsag150.html
java
if this helps, please rate
Hi Jaime,
I can upload successfully the personal greeting from an audio file. When I press the play button from the Media Master, I can hear the right audio file.
However, I still hear the default system greeting when I try to call from outside.
Attached is the info for your reference.
Your help would be highly appreciated.
Duc
Hi All,
The problem was solved. It's a Java security-related issue. I'm using Java 7U45 and when I change Java Security Level from High (by default) to Medium, I can successfully upload the personal greeting.
Duc
