How to disable SSO Login for Jabber users
ranjith raman
Hi Team,
Can you please help me the steps needs to follow to disable SSO login for jabber users. Currently jabber using SSO Login with ADFS.
Ranjith VR
Ratheesh Kumar
Hi there
https://www.cisco.com/c/en/us/support/docs/unified-communications/jabber-windows/118774-configure-jabber-00.html
After SSO is enabled on CUCM and IMP, by default all Jabber users sign in with SSO. Administrators can change this on a per user basis so that certain users do not use SSO and instead sign in with their Jabber usernames and passwords. In order to disable SSO for a Jabber user, set the value of the SSO_Enabled parameter to FALSE.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Hi Ratheesh Kumar,
Thanks a lot for the solution provided.
Is there any way to disable SSO login globally only for Jabber. Can you please help if you aware.
Thanks again.
Ranjith VR
Hi there
Please try these steps and see that helps
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/im_presence/configAdminGuide/10_5_1/CUP0_BK_CE43108E_00_config-admin-guide-imp-105/CUP0_BK_CE43108E_00_config-admin-guide-imp-105_chapter_01101.html#CUP0_TK_DE42E439_00
Disable Single Sign-On
You can disable SSO using either the GUI, as described in this procedure, or the CLI. For information about how to disable SSO using the CLI, see the utils sso disable command in the Command Line Interface Guide for Cisco Unified Communications Solutions.
Procedure
Step 1
Choose Cisco Unified OS Administration > Security > Single Sign On.
Step 2
Deselect all applications that were previously enabled for SSO.
Step 3
Click Save.
Step 4
In the Confirmation dialog box, click OK to restart Tomcat.
Hope this Helps
Cheers
Rath!
Hi Ratheesh,
This was really helpful and appreciate your help with the detailed steps provided.
Thanks again ...
Ranjith VR
