How to setup SFTP path on CUCM not
Dear Member your support is kindly appreciated.
I am trying to backup my cucm data on the network server. I have installed the SFTP/SCP Server and the SFTP_Root is pointing to a logical Drive called F:\SFTP_Root
How do i point this Path location into CUCM DRS path name?
I want my CUCM Backup information to be stored into this folder.
Remember, my SFTP is not on C:\ Drive
Jaime Valencia
SFTP path is relative, not absolute, if you want to save your backup in the root of your SFTP (wherever that may be in the machine running SFTP), just use ./
java
if this helps, please rate
