Installing subscriber callmanager 7.0 failes
saeed-zamani
Hello
I faced strange problem today. I have CUCM 7.0 as a publisher. today I try to install subscriber with excact same version.
When installation reaches integration step with publisher, I enter publisher hostname, IP address and security password but validation failes.
I do following steps to fix a problem with no luck:
1- I reset security password in publisher using "pwrecovery" and "pwreset".
2- reboot publisher CUCM.
3- change hostname in publisher.
4- connect publisher and subscriber with cross cable.
I add subscriber IP address In "server" tab in CUCM publisher. I think everythink is ok. I install publisher ans subscriber many times but I don't know why this time this problem happens.
Only difference between this time and other intallations is that when I installed publisher, I enable DNS. I read some post about DNS problem. I also disable DNS on publisher but the problem doesnt fixed. I had both servers host name in DNS.
Any help will be appriciated.
William Bell
If you have a cross-over cable between the CUCM pub and sub there is no way to resolve the publisher hostname via DNS. I have always used DNS in my installs but I do know that if there is a name resolution failure it will affect adding a new subscriber.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
