Many MTP resources
israel.castillo
Hi there
We have 2 locations, and we have 2 Gateways´s on each location, for some reason on  location B I see many MTP´s resources in gateways, (like 501 sessions in 1 and 50 in the other gw), at the other side I only see a few like 6 or maybe 20 the most, every time I make a phone call for transfering I see that gateway using MTP resources.
After checking side B I realize that many Ip´s addresses that make reference the gateway are ip addreses from other gateways from other telephony  system in the network (Telephony system that I don´t have access to).  Here's and example
51522049 52082353 mtp sendrecv g711u 38186 17550 1.1.1.1
51522050 43569719 mtp sendrecv g711u 29876 28224 1.1.1.2
51522055 52082362 mtp sendrecv g711u 35876 28532 1.1.1.1
51522072 52082443 mtp sendrecv g711u 33590 30634 1.1.1.1
51522076 52082457 mtp sendrecv g711u 43492 23906 1.1.1.2
51522089 52082482 mtp sendrecv g711u 37338 18948 1.1.1.1
51522095 52082507 mtp sendrecv g711u 36666 26284 1.1.1.2
51522109 43569843 mtp sendrecv g711u 35394 29702 1.1.1.1
51522115 52082550 mtp sendrecv g711u 46972 17716 1.1.1.1
51522116 52082552 mtp sendrecv g711u 37376 16726 1.1.1.1
51522128 43569902 mtp sendrecv g711u 39522 30738 1.1.1.1
51522169 52082805 mtp sendrecv g711u 32130 30156 1.1.1.1
51522170 43570114 mtp sendrecv g711u 39012 26824 1.1.1.2
51522219 52083013 mtp sendrecv g711u 31590 28318 1.1.1.1
51522225 43570276 mtp sendrecv g711u 36628 30968 1.1.1.1
51522239 52083112 mtp sendrecv g711u 23478 29990 1.1.1.1
51522244 52083121 mtp sendrecv g711u 25984 31868 1.1.1.1
51522270 43570465 mtp sendrecv g711u 37560 23630 1.1.1.2
51522275 52083242 mtp sendrecv g711u 33294 29356 1.1.1.1
51522300 52083333 mtp sendrecv g711u 36226 23568 1.1.1.2
I can clean them up by "no sccp" and sccp command but in a few seconds I see them again.
So my questions are:
1.- is there any other way to know why my gateway are taking many MTP resources from those gateways from the other telephony system?
I have check my MRG and MRGL and everythings seems to be ok, I even checked my device pool´s for the difference locations and they´re ok.
This is the config that  I have for my MTP resources in all my gateways.
dspfarm profile X mtp
codec g711ulaw
codec pass-through
maximum sessions software 500
associate application SCCP
Thanks for your help.
0 Replies 0
