Meeting Place 8 upgrade
Amit K Sharma
I have a Meeting Place 8.0 running which i need to upgrade to version 8.6. I do not have any previous experience (Install/upgrade) with this product.
Can anyone suggest a good tep by step procedure document for the same. A video tutorial would be really helpful.
Amit
Jaime Valencia
All the documentation is on CCO, you just need to search for it...
http://www.cisco.com/en/US/products/sw/ps5664/ps5669/prod_installation_guides_list.html
I assume if there's any video on this, you should also be able to google it...
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Java,
Thanks for the helpful reply - i didn't know that CCO has documents which can be found with the search tool.
I didn't either know that google can also help me. I will give it a try.
Let's see if someone else can understand my request.
-Amit
