Need permit single cell phone to group.
Dmitry Kishkin
Hello all. We have telephony on CUCM 4.1. And now i have task give permission to group of users call some cell phones above 60 numbers. Early this groupe have permissions to call one,two numbers.  This has been implemented using route patterns. One route pattern one number for group. But do this for 60 numbers not good. Maybe any one can help me how do this beautiful?
Jaime Valencia
Not really, CUCM all it knows is CSS and partitions, and that's how you define calling privileges.
You still need to create RPs matching that mobile and then CSS/partitions to define who can call it
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
thank for answer. thats mean, i need create 60 Route points or i can do this shortest? Maybe i can create one RP and write all numbers in his ?
Assuming you can summarize all those mobiles into a single pattern, yes.
And also assuming the same people can reach the same 60 numbers.
If the answer is no, to any of the above. Then you'll definitely will need more than 1 RP.
java
java
ok, thank you, You help me very much.
