Old MCSs with CUCM 7.1.5 and UCCX 8.0.2 migrate to be6000 version 10.0
Hello, all!
We have  CUCM 7.1.5.33900-10 installed on two MCS 7825I4 and UCCX  8.0.2.11004-12 installed on two MCS 7825I4.
We want to upagrade and migrate to BE6000 version 10x.
I’ve read that: “for MCS7800 to BE migrations, the included virtualization license is not compatible with Cisco Prime Collaboration Deployment (PCD). Use FND, ST,ET,EP if you plan to use PCD” So, Am I right that in this case we should perform jump upgrade via virtual lab server?  And we can't use PCD?
And if I understand correctly, that our upgrade/migrate steps are:
  1. Install all unused licences
  2. Perform DRS backup from CUCM and UCCX on MCS servers
  3. Do CDR purge
  4. Install cucm 7.1.5.33900-10 and  8.0.2.11004-12 in virtual lab server
  5. Perform DRS restore (see step 2)
  6. Apply phone firmware for  cucm 10 release
  7. Upgrade virtual lab server (CUCM and UCCX) to release 10
  8. Perform DRS backup from virtual lab server
  9. Perform DRS restore on BE6000 server
Thanks advance,
Alex
Jaime Valencia
duplicate
https://supportforums.cisco.com/discussion/12164951/old-mcss-cucm-715-and-uccx-802-migrate-be6000-version-100
java
if this helps, please rate
