Problem in Jabber Softphone (CSF)
aldred.benedict
Hello All,
I am currently deploying Call Manager 8.6.1 with Presence 8.6.4. I managed to log in successfully into Jabber. However, I cannot activate the softphone feature. I have created CSF in Call Manager and gives the end user (which is used to log into Jabber) enough privilege (Standard CTI enabled, Standard CCM User). I received an error (refer to attached image) when I tried to login in File > Options > Phone Account.
172.25.149.47 is my Call Manager IP Address.
Any suggestions will be welcomed.
5 Replies 5
Jaime Valencia
Instead of clicking Apply, just try clicking OK, then go and check if the credentials were accepted.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
The credentials are accepted and the icon in the lower right part of Jabber no longer shows a red X. However, when I check the status of the CSF in the Call Manager, it is still "unknown".
Then you need to bring up the config guide and make sure you're not missing anything in CUCM side.
java
java
i see. so the problem is in the cucm side?
I checked my config in CUCM once again, but it appears that everything is correct. Any ideas?
