Problem in Unity Connection DRF failure
Sandy Lee
Level 4
Level 4
Can anyone tell me if they had that king of error from RTMT with Unity Connection 7.1(5) ? I can't find anything and I would like to know what's the issue.
Here's what I get grom RTMT:
"CiscoDRFFailure Reason : DRF was unable to backup component MESSAGES.Error : Unknown MESSAGES Error AppID : Cisco DRF Master ClusterID : NodeID : dknxxxx . The alarm is generated on Thu Jun 16 02:07:50 EDT 2011"
Thanks and regards.
Sandy.
shalushar
Level 7
Level 7
Hi Sandy,
I think you are affected by this Bug  CSCsm21349.Also check these bugs also CSCth63717 and CSCtf40892.
Hope this helps,
Tx,
Shalu
Pls rate helpful posts.
