Problem to create application Billin in CUCM
felipe.ccorreia
hello people...
After completing the data to create the billing server after clicking Add is showing this message: Connection Error - Please Check the FTP / SFTP Parameters.
I did some test telnet on port FTP to make sure the service is Up FTP server where the application of billing and managed to connect.
Has anyone gone through this experience?
Jaime Valencia
Post a screenshot of your settings for billing server
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
This is the first screenshot, the second is after click in
Without knowing the config on the FTP/SFTP, that looks good enough, have you tried other path, user/pwd combination?
java
java
