Problems with CUCM 9.1 OVA file
Hello all
I´m facing problems with CUCM 9.1 I downloaded from Cisco when I run it in the VMware I got the following screen
What should I do to resolve it?
6 Replies 6
Jaime Valencia
There's no screenshot
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Sorry Here follow the image file
So, you go to vSphere, deploy the OVF, start the VM and you get this??
What OVA are you using??
java
java
Actually when I tried to open the original OVA I got the message
"the ovf descriptor file could not be parsed"
Then I opened the OVA file and took just VMDK file and created a virtual machine with this VMDK file
Then I got this message
That's not what you need to do, go to vSphere, use the deploy OVA/OVF option and use the file you download from CCO.
java
java
Brad Martin
Level 3
Level 3
That is the screen from the Singlewire Informacast server.
