Provisioning EX6 with CUCM 9
mohammad saeed
Level 5
Level 5
Hi Guys,
I have EX60 and CUCM 9.0 through provisioning I got this message " The Cisco UCM service is unavailable" this message I saw it on the touch screen of EX60?
I added the correct IP address of CUCM?
Do I need to enable specific service inside CUCM?
Thanks for all
Mohammad
Jaime Valencia
Most likely you need to upgrade to 9.1(2) and install a DevPack before even trying anything with those models
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_00.html#CMDP_RF_C91A6E93_00
java
if this helps, please rate
I solved it! CUCM 9 changed the ip address of server to the name of server, so after i changed it to ip address it works fine.
Mohammad
