10-29-2004 02:14 AM - edited 03-18-2019 03:45 PM
Quick question on the above upgrade. I have 2 UM at 4.0.3 and 1 at 4.0.2. Do I have to reregister the PAK for each of the 4.0.4 upgrades against the MAC address of each of the servers to get a new license file when I do the upgrade? Or will the current license files work fine with the upgrade?
TIA
David
Solved! Go to Solution.
10-29-2004 10:06 AM
The current licenses will work fine. There is nothing you need to do from a licensing perspective for the upgrade.
Keith
10-29-2004 10:06 AM
Keith
11-04-2004 03:44 AM
many thanks
D
11-08-2004 12:12 PM
This is what I beleive also but I was reading your Document ID 18460 and in it I read following:
Q. If the Cisco Unity software I need is posted on CCO, can't I just use that to upgrade to 4.x?
A. CCO has the Cisco Unity software but a Product Authorization Key (PAK) is required to successfully upgrade the Cisco Unity System. With the release of Cisco Unity 4.0, the licensing changed from a hardware dongle to FlexLM. Due to this change, an upgrade is not possible without a valid PAK. TAC cannot provide a PAK.
Can you please clear out the confusion ?
11-08-2004 06:41 PM
That statement is for prior versions of Unity (such as 3.x) that uses a usb or parallel dongle. Those are not used in Unity 4.x.
