04-27-2016 01:52 PM - edited 03-19-2019 11:02 AM
I'm wondering, is it is possible to get my desk phone to ring two cell phones instead of one?
Solved! Go to Solution.
04-27-2016 02:56 PM
Also you can set the limit for remote destination from end user page for a single user however you need make sure in enterprise parameters it is configured for high value.
04-27-2016 02:06 PM
Yes, simply add another remote destination.
04-27-2016 02:56 PM
05-08-2016 04:31 PM
Thanks. And would the two cell phones ring at the same time, or is it a pass from one to the other, type of situation?
