sip to isp
jramirezlaguna
                   I have a sip-trunk (several dial-peers ) that point to a public IP from my isp of voice , but I need to use two sip-trunk at the same isp with different public IP, how I do this?
Leo Laohoo
Your SIP provider has two IP addresses?
Does the SIP provider have an HSRP IP address for the two?  If not, how about a DNS entry?
Hi Leo,
Yes mi isp have two public ip address. i add some settings the first trunk-sip
cucm  7.0     in the cucm i have route patterns 9.[1-9]......
router  2821  (gateway)
config of router:
interface GigabitEthernet0/0.20
description INTERFAZ DE VOZ
encapsulation dot1Q 20
ip address 10.10.20.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip h323-id GW-VOSS
h323-gateway voip bind srcaddr 10.10.20.1
interface GigabitEthernet0/0.30
description SIP
encapsulation dot1Q 30
ip address 10.10.30.1 255.255.255.0
ip access-group securevoipsip in
no cdp enable
dial-peer voice 3006 voip
description LLAMADAS LOCALES SLP SIP
destination-pattern [1-9]......
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target ipv4:64.132.31.165
dtmf-relay rtp-nte
clid network-number 55110713
when I do the same with the trunk-sip two this does not work, sure with the new ip
regards.
