Speech Connect - Upgrades
Kevin Porter
I have just installed Speech Connect with version 1.0.1 and version 1.0.3 is available. The Install and Admin guide says "upload upgrade file via sFTP to the /tmp directory", how or where do you go to perfrom this "upload"?
Kevin Porter
You must have an sFTP server running somehwere, and set the root directory to where the Upgrade file is located then:
Open SSH V2 connection to server console
login with: scadmin
enter: cd /tmp
enter: sftp (username)@:
enter: su -
enter the root password
enter: mv /tmp/ /common
enter: cd /common
enter: sh ./
