06-15-2016 10:39 AM - edited 03-19-2019 11:15 AM
How does a receptionist transfer these calls using the Directory?
When the transfer button is pressed it I get an unwanted dial tone and it only prompts for an extension.
Solved! Go to Solution.
06-15-2016 10:56 AM
Hi Chad,
Type of Call park you can use with CUCM
Directed Call Park configuration
Directed Call Park allows a user to transfer a call to an available user-selected directed call park number. Configure directed call park numbers in the Cisco Unified Communications Manager Directed Call Park Configuration window. Configured directed call park numbers exist clusterwide. You can configure phones that support the directed call park Busy Lamp Field (BLF) to monitor the busy/idle status of specific directed call park numbers. Users can also use the BLF to speed dial a directed call park number.
Cisco Unified Communications Manager can park only one call at each directed call park number. To retrieve a parked call, a user must dial a configured retrieval prefix followed by the directed call park number at which the call is parked. Configure the retrieval prefix in the Directed Call Park Configuration window.
The following figure illustrates the call park process.
JB
06-15-2016 10:56 AM
Hi Chad,
JB
06-15-2016 10:58 AM
Yes this works fine but how do you transfer these calls using the Directory Search?
Otherwise the receptionist will either have to have a printed list of extensions.
06-15-2016 11:00 AM
are you using a tool, or doing it through Phone.
JB
06-15-2016 11:22 AM
06-15-2016 12:00 PM
Hi Chad,
if you can explain your issue in grater detail and also describe what you are looking for we might be able to direct you to resolution faster.
JB
06-15-2016 12:22 PM
When a call comes in to reception I would like the receptionist to be able to transfer without having to have a hard copy of the extensions. Using the Corporate Directory on the phone doesn't seem to be an option at the transfer screen on the phone.
The reception phones don't have enough buttons for all the required speed dials.
I just found out that Jabber only supports one line. To bad it would be a perfect solution if it supported multi line.
06-15-2016 11:12 AM
Hey Chad,
I believe you are using 8800 series phones then their is built in fast dials list which receptionist can use instead of going through directory.
If you want to do it via directory then you will have first press submit and then it will list all the users in directory.
She just needs to programme all number in fast dials and then transfer using that.Also you can use fast dial as a service with line button assigned to it.In that case she just needs to press fast dial button on phone select the number and transfer.thanks
