UCCX Wallboard not displaying Agent statistics correctly
cliffj64
I have  a UCCX 8.5 with the Gila-Wallboard running, the setup is perfect(after many hours) but the Agent Statistics is not displaying correctly. Sometimes it will show a logged in user but most times it doesn’t. enclosed is the wallboard.asp file. I am using the uccxhruser for the Informix login.  Is this a user issue or ASP issue? I am looking into the wrong table on the db_cra?
22 Replies 22
thanmad
Hey Cliff, any luck?  I'm having the same issue.  All my overall stats are accurate but the agent field is just hosed.  Spotty at best.
I have had good results using the following query:
SELECT x.resourceName, t.eventType, t.reasonCode, x.datetime FROM (SELECT t1.resourceID, t1.resourceName, MAX(t2.eventDateTime) AS datetime FROM Resource AS t1 INNER JOIN AgentStateDetail AS t2 ON t2.agentID = t1.resourceID GROUP BY t1.resourceID, t1.resourceName ) AS x INNER JOIN AgentStateDetail AS t ON t.agentID = x.resourceID AND t.eventDateTime = x.datetime ORDER BY t.reasonCode,t.eventType,x.datetime
by my understanding (schema attached) AgentStateDetail stores state changes, rather than current state, resulting in muliple records for each agent. Resource stores one record per agent, so joining them as above will produce the latest record for each agent (please note that I didn't write the query originally, I got from an open source wallboard that I updated for 8.5/9.x)
I have found that when the overall stats are good but the agents are jacked, it is the time. That is the issue.
Here is what resolved it for our site...
Open each .asp file and scroll to:
//***************************START CALC STATUS TIME MODULE******************************//
Find the entry below and either add or subtract where the current number is "1", next to the "h".
It is currently set for DST and will need the 1 probably removed during winter (add a zero[0] in
the one [1] place).
EventHappenedDateTime = DateAdd("h",1,EventHappenedDateTime)
This will have to be done for each .asp file if there are multiples
mine looks like this:
EventHappenedDateTime = CDate(strArray(0) & " " & strArray(1) & " " & strArray(2))
  ' get the current date and time
  CurrentDateTime = CDate(Date() & " " & Time())
ever figure this out?  I am trying to adapt my wallboards to UCCX 9.X and everything seems to be fine except I can only see logged out agents in my wallboard.
Did you write your own sql query? What is the query that you're using?
Here is the whole .asp.  The only part that isn't populating is the Agent specific stats.  Queue stats are rolling.  The agents I can see look like this:
Christina SmithLogged Out11:16:08Unavailable for Call
//******************************START AGENT STATS MODULE********************************//
//   Module:   Agent Stats                //
//   PURPOSE:  Retrieves Agent Sumary stats & team names and formats them for display. //
  sqlGetAgentstats = "SELECT x.resourceName, x.resourceType, t.eventType, t.reasonCode, x.resourceGroupID, x.datetime FROM (SELECT t1.resourceID, t1.resourceType, t1.resourceName, t1.resourceGroupID, MAX(t2.eventDateTime) AS datetime FROM Resource AS t1 INNER JOIN AgentStateDetail AS t2 ON t2.agentID = t1.resourceID and t1.dateInactive is null GROUP BY t1.resourceID, t1.resourceType, t1.resourceName, t1.resourceGroupID ) AS x INNER JOIN AgentStateDetail AS t ON t.agentID = x.resourceID AND t.eventDateTime = x.datetime WHERE x.resourceGroupID = '4' ORDER BY t.eventType, x.resourceName"
Set rs3 = server.createobject("adodb.recordset")
Set cm3 = Server.CreateObject("ADODB.Command")
    cm3.ActiveConnection = cn
    cm3.commandtext = sqlGetAgentstats
Set rs3 = cm3.execute
  teamID = rs3("Partner Services")
Sub getTeamName (teamID)
  sqlGetTeamName = "SELECT teamName from Team where teamID = "'& teamID &'"
Set rs4 = server.createobject("adodb.recordset")
Set cm4 = Server.CreateObject("ADODB.Command")
    cm4.ActiveConnection = cn
    cm4.commandtext = sqlGetTeamName
Set rs4 = cm4.execute
  teamName = rs4("teamName")
 rs4.close
End Sub
Sub getReasonCodeText (reasonCode)
  Select Case reasonCode
'System Codes
 Case 33
  strReasonCode = sysReasonCode33Text
 Case 32755
  strReasonCode = sysReasonCode32755Text
 Case 32757
  strReasonCode = sysReasonCode32757Text
 Case 32758
  strReasonCode = sysReasonCode32758Text
 Case 32759
  strReasonCode = sysReasonCode32759Text
 Case 32760
  strReasonCode = sysReasonCode32760Text
 Case 32761
  strReasonCode = sysReasonCode32761Text
 Case 32762
  strReasonCode = sysReasonCode32762Text
 Case 32763
  strReasonCode = sysReasonCode32763Text
 Case 32766
  strReasonCode = sysReasonCode32766Text
'User Codes
 Case udReasonCode1ID
  strReasonCode = udReasonCode1Text
 Case udReasonCode2ID
  strReasonCode = udReasonCode2Text
 Case udReasonCode3ID
  strReasonCode = udReasonCode3Text
 Case udReasonCode4ID
  strReasonCode = udReasonCode4Text
 Case udReasonCode5ID
  strReasonCode = udReasonCode5Text
 Case udReasonCode6ID
  strReasonCode = udReasonCode6Text
 Case udReasonCode7ID
  strReasonCode = udReasonCode7Text
'Catch all
 Case Else
  strReasonCode = udReasonCodeUndefined
  End Select
End Sub
Sub getAgentStatus (eventType)
  Select Case eventType
 Case 7
   Call getReasonCodeText(rs3("reasonCode"))
   strAgentStatus = strStatusCode7
   TextColor = TextColor_AgentStats_LoggedOut
 Case 6
      strAgentStatus = strStatusCode6
   strReasonCode = udReasonCodeWorking
      TextColor = TextColor_AgentStats_Working
 Case 5
      strAgentStatus = strStatusCode5
   strReasonCode = udReasonCodeTalking
      TextColor = TextColor_AgentStats_Talking
 Case 4
      strAgentStatus = strStatusCode4
   strReasonCode = udReasonCodeReserved
      TextColor = TextColor_AgentStats_Reserved
 Case 3
      strAgentStatus = strStatusCode3
   strReasonCode = udReasonCodeReady
      TextColor = TextColor_AgentStats_Ready
 Case Else
  If rs3("reasonCode") = 32761 or rs3("reasonCode") = 32762 Then
   strAgentStatus = strStatusCode8
       TextColor = TextColor_AgentStats_NonACDCall
  Else
       strAgentStatus = strStatusCode2
       TextColor = TextColor_AgentStats_NotReady
  End If
  End Select
End Sub
<!-- ##### Agent Statistics Table ##### -->
<td width="65%">
<table width=100% cellpadding="0" table align="left">
 <tr bgcolor="#E5E5E5">
  <td align="center">
  <a><font size ='<%= TextSize_AgentStats %>'><strong><%= TableColumnHeader_AgentStats_Column1 %></strong></font></a>
  </td>
  <td align="center">
   <a><font size ='<%= TextSize_AgentStats %>'><strong><%= TableColumnHeader_AgentStats_Column2 %></strong></font></a>
  </td>
  <td align="center">
   <a><font size ='<%= TextSize_AgentStats %>'><strong><%= TableColumnHeader_AgentStats_Column3 %></strong></font></a>
  </td>
  <td align="center">
   <a><font size ='<%= TextSize_AgentStats %>'><strong><%= TableColumnHeader_AgentStats_Column4 %></strong></font></a>
  </td>
 </tr>
 <tr>
  <td colspan=4>
   <hr colspan=4>
  </td>
 </tr>
  While Not rs3.EOF
 Call getAgentStatus (rs3("eventType"))
    Call CalculateStatusTime (rs3("datetime"))
    Call CheckAgentStatusBlinking
<% If rs3("ResourceType") = 2 Then %>
<% If intAgentStatsMaxDays = 0 Then %>
 <tr>
 <td><i><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= rs3("resourceName") %></strong></font></i></td>
       <td align='center'><i><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strAgentStatus %></strong></font></i></td>
      <td align='center'><i><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strStatusDays & " days / " & strStatusHours & ":" & strStatusMinutes & ":" & strStatusSeconds %></strong></font></i></td>
       <td align='center'><i><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strReasonCode %></strong></font></i></td>
      </tr>
   <tr>
   <td colspan=4>
    <hr colspan=4>
   </td>
  </tr>
<% End If %>
<% If intAgentStatsMaxDays = 1 And intStatusDays < intAgentStatsMaxDays And intStatusHours < intAgentStatsMaxHours Then %>
       <tr>
<% If AgentStatusBlink = 1 And strAgentStatus = strStatusCode2 then %>
          <td><BLINK speed="1000"><i><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= rs3("resourceName") %></strong></font></i></BLINK></td>
          <td align='center'><BLINK speed="1000"><i><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strAgentStatus %></strong></font></i></BLINK></td>
          <td align='center'><BLINK speed="1000"><i><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strStatusHours & ":" & strStatusMinutes & ":" & strStatusSeconds %></strong></font></i></BLINK></td>
    <td align='center'><BLINK speed="1000"><i><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strReasonCode %></strong></font></i></BLINK></td>
    <% Else %>
          <td align='center'><i><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strStatusHours & ":" & strStatusMinutes & ":" & strStatusSeconds %></strong></font></i></td>
   <% End If %>
    </tr>
     <tr>
   <td colspan=4>
    <hr colspan=4>
   </td>
  </tr>
<% End If %>
<% If intAgentStatsMaxDays > 1 And intStatusDays < intAgentStatsMaxDays Then %>
        <tr>
        </tr>
  <tr>
   <td colspan=4>
    <hr colspan=4>
   </td>
  </tr>
<% End If %>
<% Else %>
   <tr>
  <td><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= rs3("resourceName") %></strong></font></td>
       <td align='center'><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strAgentStatus %></strong></font></td>
      <td align='center'><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strStatusDays & " days / " & strStatusHours & ":" & strStatusMinutes & ":" & strStatusSeconds %></strong></font></td>
       <td align='center'><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strReasonCode %></strong></font></td>
      </tr>
   <tr>
   <td colspan=4>
    <hr colspan=4>
   </td>
  </tr>
<% End If %>
       <tr>
          <td><BLINK speed="1000"><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= rs3("resourceName") %></strong></font></BLINK></td>
          <td align='center'><BLINK speed="1000"><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strAgentStatus %></strong></font></BLINK></td>
          <td align='center'><BLINK speed="1000"><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strStatusHours & ":" & strStatusMinutes & ":" & strStatusSeconds %></strong></font></BLINK></td>
    <td align='center'><BLINK speed="1000"><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strReasonCode %></strong></font></BLINK></td>
    <% Else %>
          <td align='center'><font size ='<%= TextSize_AgentStats %>' color='<%= TextColor %>'><strong><%= strStatusHours & ":" & strStatusMinutes & ":" & strStatusSeconds %></strong></font></td>
   <% End If %>
    </tr>
     <tr>
   <td colspan=4>
    <hr colspan=4>
   </td>
  </tr>
<% End If %>
        <tr>
        </tr>
  <tr>
   <td colspan=4>
    <hr colspan=4>
   </td>
  </tr>
<% End If %>
<% End If %>
<% rs3.MoveNext %>
<% Wend %>
</table>
</td>
</tr>
</table>
rs3.close
//*******************************END AGENT STATS MODULE*********************************//
At the start of the agent stats module, try changing sqlGetAgentstats to the following. Right before the GROUP BY clause I've changed "and t1.dateInactive is null" to "WHERE t1.active='t'
Note that I haven't tested this, so let me know if it works.
sqlGetAgentstats = "SELECT x.resourceName, x.resourceType, t.eventType, t.reasonCode, x.resourceGroupID, x.datetime FROM (SELECT t1.resourceID, t1.resourceType, t1.resourceName, t1.resourceGroupID, MAX(t2.eventDateTime) AS datetime FROM Resource AS t1 INNER JOIN AgentStateDetail AS t2 ON t2.agentID = t1.resourceID WHERE t1.active='t' GROUP BY t1.resourceID, t1.resourceType, t1.resourceName, t1.resourceGroupID ) AS x INNER JOIN AgentStateDetail AS t ON t.agentID = x.resourceID AND t.eventDateTime = x.datetime WHERE x.resourceGroupID = '4' ORDER BY t.eventType, x.resourceName"
trying it now.  The whole wallboard seems to be taking a LOOOOOOOONG time to come up with your change.
completely broke it...  :)
Fair enough, I haven't used it on large databases (I'm using it with maybe 20 agents active at once max). If the results are still wrong then just change it back.
Mind providing a bit more detail about the results? So far it sounds like you're seeing all the logged out agents, but none of the logged in agents, correct? are there any duplicates?
I think I'm only seeing agents who have been logged out for over 8 hours and less than 12.  Looks like this
Agent Name:Current Status:Time In Status:Reason in Status:
Abigail GutierrezLogged Out8:17:03Unavailable for Call
Cilvia OrtizLogged Out9:10:13Unavailable for Call
Miriam RodriguezLogged Out8:17:13Unavailable for Call
Patricia McGeeLogged Out9:12:36Unavailable for Call
Takiya DeanLogged Out11:48:33Unavailable for Call
Taminka FranklinLogged Out8:16:49Unavailable for Call
Yolanda SanchezLogged Out8:18:30Unavailable for Call
I think bwheeler was on the right track about the time being wrong, what time zone are you in?
What's the code for your calc status time module? I think I recall a hard coded time zone compensation in the original 2.4
Central.
//   Module:   Calculate Status Time             //
//   PURPOSE:  Calculates the time an agent has been in the reported state.   //
Sub CalculateStatusTime (eventDateTimeIn)
  ' The string returned in eventDateTime is a string of the form "MM/DD/YYYY HH:MM:SS [AM/PM]"
  ' The difference between current date/time and event date/time give the time that the agent is in the current status
  ' dateDiff calculates the difference between two date values and can return this in seconds, minutes, hours, et cetera
  strArray = split(eventDateTimeIn," ")
  ' calculate the difference between current date/time and date/time of the last event change
  intStatusSeconds = DateDiff("s",EventHappenedDateTime,CurrentDateTime)
  ' we will need not only seconds, but also minutes, hours and days
  intStatusMinutes = Round((intStatusSeconds / 60),0)
  intStatusHours = Round((intStatusSeconds / 3600),0)
  intStatusDays = Round((intStatusSeconds / 86400),0)
  intStatusSeconds = intStatusSeconds - (intStatusMinutes * 60)
  ' because of the roun function used, we will need to fix some miscalculations because of rounding differences
  If intStatusSeconds < 0 Then intStatusSeconds = intStatusSeconds + (1 * 60)
  intStatusMinutes = intStatusMinutes - (intStatusHours * 60)
  If intStatusMinutes < 0 Then intStatusMinutes = intStatusMinutes + (1 * 60)
  intStatusHours = intStatusHours - (intStatusDays * 24)
  If intStatusSeconds > 30 Then intStatusMinutes = intStatusMinutes - 1
  If intStatusMinutes > 30 Then intStatusHours = intStatusHours - 1
  If intStatusHours < 0 Then intStatusHours = intStatushours + (1 * 24)
  If intStatusHours > 12 Then intStatusDays = intStatusDays -1
  ' next we convert the integers to strings to be displayed on the page
  If intStatusMinutes < 10 Then
    If intStatusMinutes = 0 Then strStatusMinutes = "00"
    If intStatusMinutes = 1 Then strStatusMinutes = "01"
    If intStatusMinutes = 2 Then strStatusMinutes = "02"
    If intStatusMinutes = 3 Then strStatusMinutes = "03"
    If intStatusMinutes = 4 Then strStatusMinutes = "04"
    If intStatusMinutes = 5 Then strStatusMinutes = "05"
    If intStatusMinutes = 6 Then strStatusMinutes = "06"
    If intStatusMinutes = 7 Then strStatusMinutes = "07"
    If intStatusMinutes = 8 Then strStatusMinutes = "08"
    If intStatusMinutes = 9 Then strStatusMinutes = "09"
  Else
    strStatusMinutes = CStr(intStatusMinutes)
  End If
  If intStatusSeconds < 10 Then
    If intStatusSeconds = 0 Then strStatusSeconds = "00"
    If intStatusSeconds = 1 Then strStatusSeconds = "01"
    If intStatusSeconds = 2 Then strStatusSeconds = "02"
    If intStatusSeconds = 3 Then strStatusSeconds = "03"
    If intStatusSeconds = 4 Then strStatusSeconds = "04"
    If intStatusSeconds = 5 Then strStatusSeconds = "05"
    If intStatusSeconds = 6 Then strStatusSeconds = "06"
    If intStatusSeconds = 7 Then strStatusSeconds = "07"
    If intStatusSeconds = 8 Then strStatusSeconds = "08"
    If intStatusSeconds = 9 Then strStatusSeconds = "09"
  Else
    strStatusSeconds = CStr(intStatusSeconds)
  End If
  strStatusHours = CStr(intStatusHours)
  strStatusDays = CStr(intStatusDays)
End Sub
//****************************END CALC STATUS TIME MODULE*******************************//
Here is my parameters for agents from the .cfg
//*******************************AGENT PARAMETERS***************************************//
Const strPageHeader_AgentStats = "Agent Statistics"
Const strPageTitleAgent = "Agent Statistics"
Const TextColor_TableHeader_AgentStats = "Navy"
Const TextSize_AgentStats = 3
Const DisplayAgentsStatsTrue = 1
Const intAgentStatsMaxDays = 1
Const intAgentStatsMaxHours =12
Const intAgentStatsMaxNotReady = 5
Const TableColumnHeader_AgentStats_Column1 = "Agent Name:"
Const TableColumnHeader_AgentStats_Column2 = "Current Status:"
Const TableColumnHeader_AgentStats_Column3 = "Time In Status:"
Const TableColumnHeader_AgentStats_Column4 = "Reason in Status:"
Const TableColor_AgentStats_LoggedOut = "White"
Const TableColor_AgentStats_Ready = "White"
Const TableColor_AgentStats_NotReady = "White"
Const TableColor_AgentStats_NonACDCall = "White"
Const TableColor_AgentStats_Talking = "White"
Const TableColor_AgentStats_Working = "White"
Const TableColor_AgentStats_Reserved = "White"
Const TableColor_AgentStats_LoggedIn = "White"
Const TextColor_AgentStats_LoggedOut = "DimGray"
Const TextColor_AgentStats_Ready = "Green"
Const TextColor_AgentStats_NotReady = "Red"
Const TextColor_AgentStats_NonACDCall = "DarkBlue"
Const TextColor_AgentStats_Talking = "RoyalBlue"
Const TextColor_AgentStats_Working = "Orange"
Const TextColor_AgentStats_Reserved = "Orange"
Const TextColor_AgentStats_LoggedIn = "Red"
