Unity 2.46 (161), NT4, and TSP 7.03b?
jhatfield
I have a customer running Unity 2.45 (161) on an older NT4 platform. I'd like to get them on the latest 7.03B TSP. It looks like 2.46 (161) is supported but the relese notes do not specifically state that the NT4 OS is supported.
Can I go to the latest TSP on the NT4 box or do I need to go to an interim release? They are running 7.02 TSP now. Thanks in advance.
kechambe
Level 7
Level 7
The entire 2.X line of code is end of support at Cisco now. Basically this means that if you contact TAC you will no longer get _any_ support.
Back when 2.4.6(161) was supported it would have been supported to install TSP 7.0(3b) on NT4 but please keep in mind that if they have any problems and contact TAC they are going to be told they are on an unsupported version of Unity.
Keith
