Unity 4.0 errors
cooper_69
Subject: Cisco Unity server Error event, CiscoUnity_AvLic[112] on UNITY
Event Type:        Error
Event Source:      CiscoUnity_AvLic
Event Category:    Run
Event ID:          112
Date:              2010/08/18
Time:              06:10:38
User:              N/A
Computer:          UNITY
Description:
Unexpected result in CAvLic::QueryS. 0x80040e31 Timeout expired
I have researched this error and all referances point to initial installation and configuration for created of the DB
My question is would I do the same steps:
Complete these steps in order to solve the issue:
  1. This issue can happen if the ReportDB is not created. Check if the ReportDB is created and if it is not created, complete these steps:
    1. Delete ReportDb.mdf and ReportDb_log.ldf.
    2. From the command prompt, switch to the \Commserver\Reports\SQLScripts directory, and run the this in order to re-create the ReportDb
      osql -E -i ReportSQLCreate.SQL
  2. From SQL Enterprise Manager, verify that the new ReportDb is attached, and run the CUICA again.
Thanks in advance for your help
Rich
David Hailey
Rich,
This is indicative of an issue that might occur during installation of Unity 4.0.  Specifically, the procedure you listed is part of a troubleshooting procedure for when this error is thrown while running CUICA - Cisco Unity Installation and Configuration Assistant.  I'm not quite certain that the same circumstances would apply to a system that has been up and running for a while.  Can you confirm:
1) You are NOT installing Unity 4.0 (you'd be a bit behind the times, but it's possible I suppose)?
2) When did these errors first start occurring and have you noticed any issues with adding system components (subscribers, etc)?
3) Is the Report DB created or not?
Hailey
Hi David,
Thanks for your response!
No, this installation has been running for years now (yes, behind the times)
I will check with customer on the other 2 questions.
It happened this weekend out of no where, received 10 or so email notifications for this event.
Rich
