unity 4.2.1 Busy signal after the message
znaqvi
Sometime when I get the message in my inbox and I check I will hear the busy signal at the end for about 2 to 3 seconds.
Like to find out where would I troubleshoot this problem ?
TIA,
16 Replies 16
If you're going to be doing much with LearnTones, you should first read through this document.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a0080093c1e.shtml
In particular it has a lot of detail on disconnect signalling and usage of TrimDisconnectTonesOnRecordings, including how Unity calculates the ammount to trim. The basic trick is that if you have 2 disconnect tones defined in the switch file,[Switch Disconnect Tone] and [CO Disconnect Tone], both need to add up to the same ammount of time. A mismatch here can result in undertrimming or overtrimming as you are reporting.
-Eric
After re-running the learn tone the busy is gone.
Problem fixed.
Thanks for your help.
