Unity 5.0 to Unity Connection 8.5 Migration.
Nagajothi
planning to do a unity to unity connection migration using COBRA tool. Do we have to do the Integration between the CUCM and Unity Connection before start import using the COBRA or COBRA takes care of it?  please suggest.
lindborg
COBRAS does not create links to any external systems (including phone system connections, LDAP links, digital network connections to other Connection or Unity servers, VPIM attachments etc...).  The help goes into a bit of detail on this - but the short version is that you may be migrating between systems that have different phone system configurations - you wouldn't want COBRAS wiping that out - regardless reestablishing connections to external systems is incredibly difficult to do smoothly anyway.
So you need to configure your Connection server ahead of time - make sure it's taking calls properly etc... and then import your data.  The COBRAS wizard will ask you to map phone system associations from the backup to any phone system(s) you have configured on your new Connection server so everyone is linked up properly after the restore.
David Hailey
You will need to stand up integration between CUCM and Unity Connection.  COBRAS does not get that information for you.  There is a lot that COBRAS does as it is a great tool and has come in quite handy for me.  However, there are some things COBRAS does not do and they are well docmented here:
http://www.ciscounitytools.com/Applications/General/COBRAS/Help/COBRAS_Briefcase/COBRAS_Briefcase.htm#_Toc276653808
Hailey
Please rate helpful posts!
