UNITY AND UNITY CONNECTION - USABLE VARIABLES
5mgagnon
Where I could find a list of usable variable in Unity and Connection ?
Like :
%Alias%
%EXTENSION% ect
Tray Stoutmeyer
I am assuming this is for Bulk Import? Could you specify? I will go with that assumption for now. If so, use this doc...
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user_mac/guide/7xcucmacappa.html#wp1013589
Specifically use this doc to get to the link in the paragraph on what is allowable in the csv..
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user_mac/guide/7xcucmacappa.html#wp1013626
Thanks!
Tray
Its not for Bulk Import. Its to push is as a Transfer String on a callHandler:
transfert to: 9NPANXXNXXX ,  ,  %USABLED_VARIABLE%
I do know you can use some var for using it in Unity VM before.
The GUI design doesnt understand this possibilities, but you can push it in the Database. and it Works (Solution was provide by Jeff Lindborg)
Iwas looking to do something similar.
But there is no information about all possible variable that are "availaible" to Unity
