Unity Connection 7.13 unified messaging
master001
Level 2
Level 2
Hi everyone,
Just wonder how I could verify this CUC 7.13 comes with unified messaging feature.
I don't see " unified messaging" tab on CUC admin web page, attached the license catpure.
Your info/help is much appreciated.
Master001
5 Replies 5
Jaime Valencia
UM/SIB is a 8.x+ feature
http://www.cisco.com/c/en/us/support/docs/unified-communications/unity-connection/118758-technote-unity-00.html
java
if this helps, please rate
Thanks Jaime !
Since UM/SIB is a 8.x + feature,  is it possible that we could deploy unified messaging on Unity connection 7.x ?   if possible, any high level of idea?
On Unity, there are lots of UM deployments as far as I know.   Thanks in advance.
Master001
No... you need CUC 8.x+ in order to configure UM, did you review the link????
java
yes, I reviewed the link.    It just surprised me that CUC 7.X doesn't come with UM feature, as Unity already supported UM long time ago.
And CUC became the replacement in the long run, but it took some time to get UM, if you want UM, there's no other way besides upgrading. Best you could get is simply to FW the messages to another email, which you can still do up to the latest release of CUC, but that's not real UM. CUC will forward the message and won't care what happens to it.
java
