unity connection import greetings from exchange 2016
shafeen
Hi All ,
I have a unified messaging integration(sip) between CUCM and exchange 2016 , is there any way to export the greetings/messages from exchange 2016 and import them into unity connection in bulk? .  The exchange 2016 users are migrating to Office 365.
JeffG1
Level 3
Level 3
You can export out the EUM prompts with the following powershell commands
$prompt = Export-UMPrompt -PromptFileName "Nameofwavefile.wav" -UMAutoAttendant AutoAttendantName
Set-Content -Path "C:\Nameofwavefile.wav" -Value $prompt.AudioData -Encoding Byte
From there you might need to modify their format with an audio editor.
JeffG1
Level 3
Level 3
