Unity Connection integrating to openldap
AskQ2Forum_2
                   Hi we have a customer that has Openldap directory service  - can unity connection integrate to openldap , is there any differences between integrating openldap with the ldap integration (or is it the same i.e. same attributes, fields etc).
Any documentation to support?
Unity Connection 9.x
thanks....jag
Jaime Valencia
Requirements for an LDAP Directory Integration
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/requirements/9xcucsysreqs.html#wp562632
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Jamie
thank you very much
