Unity Connection upgrade
jhitt-limited
Level 4
Level 4
OK, I went through the upgrade on the inactive partition of both my publisher and subscriber Unity Connection (8.5).  Unfortunately, we had some other network issues that caused us to decide to not do the reboot to the updated partitions.  Two questions: 1) is there any problem that I didn't complete the upgrade with the reboot?  In other words, can I run as long as I like on the old version?  2) When I am able to do the upgrade, do I need to do anything special before I re-run the upgrade on the servers?  Like to clear space?
Jill
Jaime Valencia
1. Yes, just be aware you'll lose all changes done between the upgrade and the time you switch versions.
If you want to keep the changes, you'll need to run the upgrade again.
2. No, assuming nothing has changed, if there's any need for it, you'll get the error duing the install.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
