Unity Failover Question
BWTG
Are their any caveats or known issues to doing the Unity Failover configuration after the CM & Unity configuration. I would like to get the CM-Unity configuration setup and working and then do the Secondary Unity server. I know that you can add the Secondary server but is it beneficial to do the Unity Failover configuration before the CM-Unity integration.
Markus Schneider
Doesn't matter. The primary and secondary are integrated independently to the CCM, but it doesn't really matter if you do the integration first or last.
Anyuseful links on unity failover would be highly appreciated.
