unityadmin not associated with Unity subscriber
NAVIN PARWAL
Level 2
Level 2
Folks,
I recently installed unity 4.1 and when I launch the unity admin page, i get a message that says that unityadmin user is not associated with the unity subscriber? how can i fix this please, all posts will be graded.
7 Replies 7
Jaime Valencia
you need to associate the user with the grantunityaccess tool
Accessing the Cisco Unity Administrator
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/405/administration/guide/ex/sag_0020.html
javalenc
if this helps, please rate
java
what wrong am i doing?
C:\CommServer>GrantUnityAccess -u unitydomain/unityadmin -s unityadmin
Failed getting subscriber's object ID from database.
Logfile generated: C:\CommServer\Logs\GrantUAccess_4817955d.txt
-- Operation FAILED --
it's not unityadmin, usually it's the eadmin
GrantUnityAccess -u \ -s eadmin1324234
javalenc
java
pls help when it eadmin1324234?
my domain is unitydomian and i have a user by the name of unityadmin,what should i do so that he has access to unityadmin page please.
this will work I promise
GrantUnityAccess -u \ -s installer
this is what it should be
after you are done you can do this
GrantUnityAccess -l
rlp
GrantUnityAccess -u unitydomain\unityadmin -s installer
rlp -- Randy
Navin, what happened?
