Unknown phone messages
bpoole1975
I'm having the following problem.
Unknown phone messages being routed to Domino accoount EAdmin35cf39ee. You can hear someone talking and then there is a pause and then the person talking again.
5 Replies 5
Tommer Catlin
Messages will go to the EAadmin account when it cant be delivered for some reason. Unity will record the voicemail and is supposed to route it to the person it was intended for. If it cant, it will dump it in the Admin box for sorting. This could have came from a call handler that had "record greeting" after the message, or a broken subscriber mailbox.
Possibly run dbwalker and look for broken links in the database if you are getting a lot of these messages.
Can you run dbwalker during the day without impact to users or is this usually an after-hours type of maint issue? Thanks.
id make a dirt backup, then run dbwalker. Both I would do after hours.
I ran dbwalker and no errors where found.
Christopher McAlpin
Community Manager
Community Manager
By default, the default Operator Call Handlers "Closed" greeting after greeting action is set to send the caller to the Example Interview Handler. The Example Interview Handlers message recipient is the Example Administrator account.
