Voice Mail Port Problem with CUCM 8.5 and Connection 8.5
hectorgo
Hi im having a very strange problem witch the voice mail ports between a CM 8.5 and a Cisco Unity connection 8.5 , i configured them and they registered and all was working fine, however when i rebooted the servers the ports stayed in status unknown i tried resetting them both sides, re adding config both sides and nothing after hours of trying and deleting and adding the same config it worked again, however we have a power outage today and the same thing happened again status unknown and still i cannot get them to register again. Any ideas or help would be appreciated.
gmgarrian
Level 4
Level 4
I'm not sure but it could be a DNS issue. Is DNS configured or are you just using IP addresses?  Make sure everything is resolving correctly.
All is configured with ip addresses , its really weird after 3 hours they registered again... but if i reboot them same problem will happen
