Where is Call Viewer for CUC in CUCMBE??
tcekada
Used to be able to click on the Wrench Icon in the Windows based versions of CUC and UNITY to get access to all the wonderful tools in there. Now I am installing and configuring a CUCMBE server that has a Linux version of CUC 2.1.2.1000-380 built into it. What/where is the equivalent of the "wrench" icon that leads all helpful tools like "Call Viewer", "TTY Angel", etc, that were in the windows version??
Already searched ciscounitytools.com could not find any downloads for "Call Viewer",etc for the Linux version of CUC.
It would really be a shame if these tools are not avaiable in the Linux vesion, especially "Call Viewer"
Thanks in advance,
Tony
culittle
There is no longer a call viewer.... closest tool is under Telephony Integrations, Port, then click on the port. It gives you the information on that one port.
Port status Monitor has to be downloaded from Ciscounitytools.com. Follow the help link for installation and configuration instructions.
http://www.ciscounitytools.com/App_PSM_LL.htm
Please rate if this answers your question
