Any Tools to change system passwrods in Unity System
rayon.man
According to Unity Installation Guide, we need to define the following account/password:
1) administrator
2) UnityInstall
3) UnityAdmin
4) UnitySvc
5) UnityMsgStoreSvc
During the installation, we only apply default password on these account. For security reason, the user want to reset those account passwords when it is in production. Is there any tool to accomplish it? Thanks!
We are using Unity Voice Messaging 4.2(1) . Thanks !
jbarcena
Level 9
Level 9
Just go to Active Directory, find those accounts, right click, select reset password. Reset the password and then you need to restart each service that is running under those account (so is actually easier to reboot the server).
//Jorge
I'm afraid there are some extra steps I need to do after reseting those passwords. For example, updating service parameter using those accounts.
Besides, what will be affected if I change the password of SQL SA?
Just change it, reboot the server and that's all? Thanks a lot!
