I have the following set-up for a Right Fax 7 install -
PSTN > VG > MGCP > CUCM > SIP > Right Fax
the rigth fax server is going to be sitting in the DMZ, so l was wondering if anyone knows what ports the RF server uses?
sip 5060/tcp
sip 5060/udp
mgcp-gateway 2427/tcp
mgcp-gateway 2427/udp
mgcp-callagent 2727/tcp
mgcp-callagent 2727/udp
Do l require any other ports to be opened up?
James
