07-02-2014 10:52 AM - edited 03-19-2019 08:21 AM
CUCM 8.6.2
CUC 8.6.2
Has anyone experienced an issue when a person calling from a Verizon iPhone consistently cannot hear the called parties greeting play or leave a message? I have some users with Verizon iPhones that are reporting this issue. Our entire company has been converted to Cisco’s phone system.
Problem Example:
Employee A calls from a Verizon iPhone to Employee B’s DID, Employee B doesn't answer the call within the standard RNA duration, when the greeting should play but they hear nothing but silence. Occurs when calling any DID number at that location.
- Attempts to leave a message anyway are unsuccessful.
- Attempts to call the site’s main number and then be transferred to the DID, were also unsuccessful.
Successful Example:
Calls same DID number but with any other type of smartphone or the Verizon iPhone (noted below) - is able to hear the greeting play and leave a message.
So, far I’ve narrow down the Verizon iPhone phone specs:
Problematic phone is:
Carrier: Verizon
Model (4s, 5s, 5c..): iPhone 4s
Current IOS version: 7.1.2
Successful phone is:
Carrier: Verizon
Current IOS version: 7.1.1 (11D201)
Anyone have any suggestions besides switching Carriers?
07-02-2014 02:02 PM
What do you have for PSTN connectivity? Doubt its a system problem, very strange.
07-03-2014 06:46 AM
Agreed, it is a very strange issue.
The particular site reporting this issue has a PRI circuit.
We have a centralized CUCM environment using SIP to connect to the local Gateways. But the majority of our local Gateways have PRI's and a few have POTS lines (I'm not positive if call to a POTS site makes a difference).  Eventually we'll be moving to SIP trunks from the Gateways.
07-03-2014 04:51 PM
Does this issue only occur when diverted to voice mail? Does it work if the person answers the call?
Are you able to debug the ISDN q931 to compare a working and non working call?
07-03-2014 01:06 AM
I agree with George, maybe more involved with carrier connection especially if you are using SIP for this and not ISDN
