CIMC vkvm won't start
masood-firouzi
Hello all,
on one of my SNS-3755-K9 Applience can not open vkvm.
after clicking on start and accepting "Load KVM Certifivate" i recieve a blank new Page and 3 Errors (see Screen Shots)
Please take a look at this Problem as sonn as possible. Reset Factory - Reset every Thing- HARD Reset and Hard Shut down didn't help.
rwilkinson
I have the same issue with SNS3715-K9. Did you find a solution?
Richard.
Steven Tardy
Are you in the same network / VLAN?
Is there a firewall between you and the CIMC?
Is TCP Port 2068 allowed through any firewalls?
Is CIMC listening on 2068?
Probably need to open a TAC case to have TAC review what is causing this to not work.
Turned out there was a firewall between the CIMC network and the jump host. Port 2068 has been allowed and it works now.
Richard.
